MQA through the Direct Stream
I am planning on purchasing a Direct Stream DAC. I currently run an Ayre QB-9 DSD via a ultraRendu as a Roon end point. No MQA here.
So I was thinking of still using the ultraRendu to make the new DSD a Roon endpoint and listen to MQA files. I’m concerned that I will need the Bridge II for MQA. I’m sure the ultraRendu will work with the PS Audio DSD but not sure if the DSD will see MQA files through the ultraRendu.
Yes, you are correct. MQA only through bridge
But sounds glorious!
