It’s on a Timbernation wooden rack. It’s only recessed about a foot.
As AL suggested, just move it into your room and find out first hand.
My guess is that your concern is overblown.
I think my concern was overblown 2 years ago when I built the room. But I think I’ll just leave it as-is. What I thought I met get as far as feedback is something like, “Are you kidding? I moved my turntable to a separate room and the soundstage opened up and I could hear vocals like I’d never heard and sonics blew me away…when I moved it back, it sounded like crap.” You’d think I’m joking but here’s a totally true story: I read something from a guy who claimed that he could tell the difference in audio between types of power wall PLATES - that plates made from some kind of special composite really opened things up compared to your standard Home Depot plastic type.
Some thoughts.
First, although concrete would seem to be able to absorb vibration, those living in CA having gone through a significant earthquake know otherwise. I live in a community apartment on the 4th floor. Above me on the sixth is a dining facility. The floors and ceilings are concrete held up with massive concrete vertical beams, two of which are on the outside corners of my bedroom. Until recently, I knew when folks came in for breakfast as I could clearly hear the chairs scraping on the floor, vibrations carried through the concrete floor to the concrete beams down to my concrete ceiling. A total remodel of the dining facility totally fixed the sound transmission problem, demonstrating that isolations is possible.
For informative videos on YouTube, see: https://youtu.be/o1S2pdRhOx4?si=4hm4Dl8kW9Q9upKj
Quite informative and, as is typical, you leave “knowing” its far more complicated than you thought. Those looking to spend money, sorry, but no hard recommendations will be forthcoming.
Ron, what is that lamp?
Mine is the clamp version. $69.00
