Dear All,
I have a strange problem with my NPC.
When I listen to vinyl records right channel is much lower than the left. To
I plugged my NPC on other inputs of my amplifier (RCA and XLR), but the problem is still present (other devices work normally on these inputs).
Using VinylStudio to register (in 96 Khz/24 Bits ) my records, the result is strange : on the left channel everything is ok and perfectly recorded. On the right channel, it’s simply inaudible (crack, larsen…). To test, I switched the phono cables and RCA unsuccessfully.
I reset my NPC without change (firmware in last version).
Your help is welcome
Arnaud
