PMG pre Vs PassLabs xp12
Hi all from down under
I have about $15000 AUD to spend and am about to audition both these units as I believe my preamp is the weakest link in my system & they are about the same price.
Need more info? Just ask
What are your thoughts on these?
Cheers
Andy
Those two preamps are both great choices. Can’t go wrong either way.
I have not heard them back-to-back. But I expect the PMG to have greater transparency with the XP-12 to present with more warmth (not that the PMG is cold, rather it is neutral).
Why do you feel your current pre is inadequate? What is it?
PMG Pre is closer to XP-22 than 12.
Hey all…
My system consists of:
Pre: Stellar Gain Cell
Amp: BHK250
Streamer/DAC: Lumin T3
Power: PS Audio P10
Sub: REL T7x
Speakers: Amphion 7LS
Cheers Andy
The reviewer says he still holds the XP-22 “near and dear to his heart”. What is one to conclude from that? Nothing, I think.
He stated that the PMG was more dynamic. The important point here is the PMG Pre is more competitive to the XP-22 not Xp-12 the less costly option.
