Doug Macleod stopped by for a private concert last night and I had a front row seat. The admission price was $24.98 paid to Acoustic Sounds for the DSD recording. It sounded so nice that Eric Clapton & some very talented friends also visited and did a great tribute to J.J. Cale. It doesn’t get much better then this! Thanks PS Audio!
Diana Krall stopped by my man cave last night…just left singing “Walk of Shame” …
All this talk makes me glad that I didn’t play any Rob Zombie last night.
audiobill said Diana Krall stopped by my man cave last night.........just left singing "Walk of Shame" .......I didn't think of that! Even though I don't care for her music maybe I should have tried some Katy Perry. Naw my wife would kill me!
Nice!! Love it!
Teddy Charles Tentet was just in my room. Man, how did they do that concert in MONO? ![]()
It is a lost performance skill many used to possess.
lwin1949 said Doug Macleod stopped by for a private concert last night and I had a front row seat.I LOVE Doug MacLeod! All his stuff is at least really good, most of it great!
You can only imagine the mess I had to clean up when the Rolling Stones left my room…
J’ai en ce moment environ 750 hrs de bruller
Avez-vous remarquer avec la DS que si on écoute a haut volume, tout es parfait, les basses, l’image 3D, la réalité, tout es merveilleux
Si on baisse le volume, on perd beaucoup de cette magie.
Le PWD a très bas volume, tout reste en place. l’image et surtout la chaleur, la magie reste devant vous.
Je m’ennuie de cette magie a bas volume, mais j’adore le son live dégager par la DS
Quand pensez-vous ?
At the present time i have 750 hrs burned in my DS
Did you notice this with DS when you listen to hi volume, everiting is ok, bass, 3D image, the realistic, all is perfect
When i lower the volume, the magic soundstage, is very poor.
The PWD at very low volume, all is in order, image, sounstage, 3D bass, is excellent.
I miss the sound effects, at low volume
What do you think.
When you listen at low volume (say less than 60 on the volume control) instead use the attenuator (press the “filter” button on the remote) and use a higher volume setting.
I.e. Volume = 55 and attenuator off is about the same as Volume = 95 with attenuator on.
I use a Mark Levinson 380s Preamp
My DS volume il all at 100
magog saidDid you notice this with DS when you listen to hi volume, everiting is ok, bass, 3D image, the realistic, all is perfect
What do you think.
I do not have that issue at all.
Un autre propriétaire de DS et membre de ce forum québécois, Ghyslain que Gordon connaît a remarquer la même chose
A faible volume il y a plus la magie du PWD
magog said Un autre propriétaire de DS et membre de ce forum québécois, Ghyslain que Gordon connaît a remarquer la même choseDid you try my suggestion? Or are you listening to levels above 60 and still feel that something is missing? (Or perhaps I misunderstood the machine translation of your message?)A faible volume il y a plus la magie du PWD
Ted Smith said When you listen at low volume (say less than 60 on the volume control) instead use the attenuator (press the "filter" button on the remote) and use a higher volume setting.I.e. Volume = 55 and attenuator off is about the same as Volume = 95 with attenuator on.
My DSD …i’m listen the volume at 100, but i have a preamp.
always at 100 my DSD
I love my DSD . I dont return to my PWD
Its a remarq. At low volume …the magic soundstage is not here. With the PWD …at low volume the magic soundstage its here.
Excuse my english
i do not return to my PWD I love my DSD
yesturday, dire strait is on my room, just for me. Wow wow wow, its wonderful
Wait till about 700 hours. I know that is a lot of break-in, but damn, it just KEEPS GETTIN’ BETTER!![]()
I too thought the lack of ‘magic’ at lower volumes might be due to a lack of break-in – but he said in his original post that he has 750 hours on his DS. Mine’s got about 400 and is still improving. We’ll see how long this continues.
