Strangely, I found that in Roon if you create a playlist, it loads all the tracks on all disks, but the disks do not necessarily have them all in the right order, so the playlist needs a bit of sorting.
This is when the CD diehards come out of the closet!
Yup. Years ago I gave up on āalbumsā and ābox setsā for classical music when I ripped them to NAS: a total pain. In addition I find it very annoying to have each track title including text for work type, opus no., track no. and the unique track details; in many cases the composer name was included as well! I guess this is done as a belt-and-braces measure to ensure essential meta data is displayed, because there is no universal standard.
My solution (apologies as Iāve stated it many times before in this forum) is to use album as āworkā (i.e. album = composer + work type + opus/no.) with ātrackā then only containing the movement/aria description.
I went through the process with box sets a long time ago. One thingās for sure, Beethoven never had a server and nobody told Mahler to write what he likes as long as it fits on one side of a CD.
You cannot play SACD discs because the drive is BluRay.
However you can play DSD files from ripped (transcoded) material burnt on a disc media or from the internal SSD.
The Pink Faun 2.16 weighs 38kg, nearly 4x the Rockna. The 2.16 is essentially 3 massive linear power supplies, oh with a computer and very low phase noise clocks, and your output(s) of choice.
I have no affiliation, just a very happy customer. Iāve owned the 2.16 since July, 2018.
Ditto - that is if you can help me lift it on my rack⦠You wonder why I went for the 0.40in thick glass shelves at 220lbs weight spec⦠that was a really good review tooā¦
5ā lift of close to 100lbs and man it better holdā¦
I didnāt mean to slam the Rockna. I donāt know much about it but it appears to not have nearly the same focus on power supplies that the 2.16 does.
Re: 2.16 review, I was somewhat surprised he chose to not use it with HQPe and he really seemed to like their uber-expensive power cord. I happen to prefer HQPe (by far over Roon alone) and a far more modest power cord - from a P10, of course.
I donāt know the Pink Faun server, however at first glance it doesnāt seem to be the same type of device when it doesnāt contain a disc drive?
The Rockna works well and it is nice to have everything onboard one unit.
The upcoming Rockna devices will not contain a disc drive.
Sound wise it betters my Lumin, Aries and Microrendu. I bought it because of itās PS compatible I2s output and Roon capability. The web interface is also nice.
Thanks Frode
This device seams not so common. I am the owner of a Rockna Wavedream Signaturen DAC, so I know the outstanding quality of Rockna. But this Server is also expensive, and the same price League as the upcomming Octave. With this background, - do you think its worth the money?
Do you know more about this new upcomming devices ? Sounds Good ā¦
Thanks
Chris
Thereās much in the way of debate about this in the halls at PS. It will certainly have the capability (processor wise) and thereās talk of having it, yes. Weāll see how it manifests itself. I have this killer idea for DSP/EQ that I am dying to implement⦠hush
hush for right now.
Octave will be launched in phases, the first will be what we call MVP (minimum viable product) and then features will slowly be added over time. Weāre working hard on perfecting the update process so itās transparent to the users and easy.
