Search engine contest:
This morning, I realize how bad internet has became!
Simple search for a picture, here the request:
“Flower Pot sitting on a hifi speaker”, after 30 minutes, I gave up
10 years ago, you have found this information quick, now just a bunch of garbage!
I have try, french/English, nothing, nada!
Google, Safari, DDgo, didn’t find anything!
Do you have others simple like that, that internet is unable to furfill?
I used DDAI and asked it to create one. Never used it before but it gave me exactly what I asked for.
I took a picture!
here my picture, putting the flower pot is the worst sound ever, I was about to discard the receiver! a Pioneer 3600!
thanks, is duck duck go AI? so it create it, instead of finding it!
does it count?
Counts for me
Maybe something is amiss with you computer. After 1 sec:
I was trying to get a picture for the post, none appear!
All I got was Robert Plant
:rofl:
For some reason these difficulties don’t come as a surprise.
Tip: if you’re using duckduckgo, use it to anonymously search google. You’ll get better results, and without the tracking. You can search google and other sites/search engines directly through the duckduckgo search line. “!gi” will redirect your query to google images, for example.
Using the search string “!gi plant on hifi speaker” gives some ok results
Just learn
You could also, go in tool, under the search bar, and change all result for verbatim in google, better result
I found 3 picture that way!
different kind of pot!
