Hi Patrick
I’ve been on the usb staircase for the past few months, starting with a 5m cable, to a 1m cable, to a usb hub etc., etc. I zoned in on the 5V usb supply because I could get at it, and was surprised by the results – it had a real effect. Rather than filter the PC usb 5V supply, the best strategy is to simply eliminate it.
For a quick and dirty solution try 3 x AA batteries (4.8V) in a battery holder. Strip back the cable insulation on a cheap compliant usb cable at the PC end, and tease out the 5V (red) and Gnd (black) wires. Cut the red wire and strip some insulation from the black, leaving tape and braid shields connected. The simplest arrangement is connect the battery directly to the black wire and the red wire on the downstream end. A resistor between the battery +ve and the red wire, almost any value up to say 1k5R., will help protect downstream equipment. Another resistor ca. 100R can be inserted in the black wire towards the PC, which will help cut noise on the Gnd wire.
It works. The Directstream doesn’t really require much current on the 5V wire and I’ve found the battery lasting months. I don’t even bother to disconnect it.
A further very real improvement is to incorporate a usb hub. Use a cable arrangement as above from the PC to the hub, power the hub from a linear 5V supply (rather than the supplied wall-wart), and use a second cable as above to get from the hub to the DS DAC. Very good.
That’s about as far as I’ve gone with batteries and wires. Well worth it. I’ve not used a jitterbug or filter on the usb data wires, which would be worth trying.
The fundamental sound of the system doesn’t really change - this is largely determined by speakers, stands, room etc. What changes is the detail, presence, dynamics, separation etc, and the ear is hungry for it.
Moving on, I’ve outlaid for an Audiobyte Hydra Z. It’s very impressive and will stay in my system. It converts usb to I2S/SPDIF and has produced the best sound so far from my system. And it in turn is improved by eliminating usb 5V with cables, batteries, linear power supplies as above. When I’ve sorted it all out I’ll post some comments.
Hope this helps.
Lonan
