Airlens-qobuz connect
i tried everything,but my airlens just purchased,don,t connect to qobuz connect.Spotify no promblem…living in Europe, belgium
You might have already tried this, but if not you will need to update the Airlens firmware - search for Qobuz connect Airlens update on this forum.
Watch this…
I had a difficult time using Qobuz connect also. Take a look at this post of mine and the replies below it. In addition to the firmware updates, the key ended up being using the stupid little icon to select the AirLens as the playback method, an icon that I could not originally find.
so many parallel threads about the AirLens and Qobuz Connect
Agreed. I vote to merge!
I did that upgrade but also a earlier upgrade…and working perfectly…sound quality is even more better then with Spotify…thanks…i am a zero in digital engineering :wink::blush:
Thx,it worked.But i needed also another update shown in more earlier video
But all good now…
Regards Rudi
Verzonden vanaf Outlook voor Android
