Airlens redux
I posted this summary of the AL capabilities some time ago and believe all of it is still valid. It got lost in the thousands of posts on the other thread…
Heres a video where Paul explains the Airlens.
Ditto. 20 1000 to 20 20.
Not clear on the advantage of Airlens over BridgeII. I only play audio files from my PC over the Ethernet network. Sonic advantage?
The AirLens sounds much better than the Bridge II for several reasons. First among them is that it is external. Just removing the Bridge from the DAC helps sound quality in the first place. Then, the AirLen’s output Digital Lens and its galvanic isolation is definitely better.
And this is regardless of whether you’re streaming or pulling from a NAS.
Can anyone inform me on how to play Octave Radio through the Airlens using Jriver MediaCenter? Thanks in advance!
1- In Jriver go to File  Open URL and paste the following URL
https://octaverecords.out.airtime.pro/octaverecords_a?_ga=2.139116787.1781832620.1687634712-199058362.1687634712
2- Check Show web media options
3- Check add stream to web media
4- When the stream is added click play
5- the stream will be added to your web media folder
