AIYIMA T20 Fully Balanced Tube Preamp With Stella S300
Hi! Newbie here!
Interested in trying the AIYIMA T20 Fully Balanced Tube Preamp ( https://www.aiyima.com/products/aiyima-t20?variant=51052379177236 )for the S300 amp. It has this specs:
RCA output: About 4 V RMS; XLR output: About 6 V RMS (typical max)
Will this cause any input overload on the S300 needing some attenuation to match Stellar input sensitivity?
Welcome aboard!
Double check with the PSA support team but I suspect you’ll be fine. The Stellar Gold preamp specs indicate 10/20v SE/balanced output. Specs for the GCD that would be commonly paired with the S300 is 5.3/20.
Much appreciated for your help! Will do
