Manual edits:
Page 1, Outputs: “Please be advised that the XLR output has twice the output voltage as the RCA input.” Should read, “. . . RCA output.”
Page 1, Unpacking the Unit: “Use the included cotton gloves . . .” My unit had no gloves included.
Page 2, Warranty Registration: “. . . go to www.psaudio.com and click on My PS > Register Products”
“. . . go to the PS <strong>Audio</strong> website and look at the <strong>My PS > My Products</strong> page”
“Full warranty information is included <strong>at the end of </strong>this manual.”
Page 2, Connecting to Analog Sources: Delete comma in “connect via the balanced, XLR if possible.”
Page 2, Assign Input Names: Delete comma in “later in this manual, for details.”
Page 4, Front Panel Logo Standby Button: “In addition, the outputs are also turned off leaving only the unit’s critical internal solid state circuitry active.”
Page 4, before Custom Naming, add Setup Mode: “Once selected, hold the selector button down for 3 seconds to enter the setup mode. Setup mode allows you to customize each input and features multiple screens accessed by pressing the selector button.
The first screen is balance. Pressing the selector button again toggles to the Trigger screen. Another press displays the Version screen and so on. Each screen is addressed is the following section.”
Put the sections in the order in which they appear on the unit.
Page 4, Custom Naming:
Continue toggling through the screens until you reach the input name screen (the fifth screen). By default, the inputs are named Input 1, Input 2, and so on. Hold down on the selector button until “Edit” is displayed in the upper right corner of the screen.
Page 5: BOLD the bit about the escape character and what it does.
Page 9, Trigger Settings: Delete comma in “ . . . to turn on the BHK Preamplifier, will also turn the rest of the system on.”
Page 14, Hum Busting: “. . . department store-type outlets . . .” or just remove ‘type.’
Remove single quotes around ‘matching transformer’ or switch positions of the single quote and period following ‘tranformer.’
