BHK 300 and speaker hiss
Hi, Jim,
It turns out it was the DSD Sr causing the problem. I could hit the attenuator and that would silence the hiss, but then I’d have to turn up the volume sometimes to maximum to get the loudness level I wanted.
I was told the solution would be to get a Signature pre-amp. Instead, I bought a Cary DMS-600 to replace the DSD, and the problem is gone. Plus, the DMS is a superior player in all categories compared to the DSD (sonically, I think the DMS is better, but that’s an individual call. They’re both wonderful to listen to).
Hope this helps, --David
interestingly enough i had to take my preamp out of the system for a bit, and drove the amps direct from the DSD DAC. still got some tube noise. not sure if i really understand why but i think with tubes, that may always be a bit of an issue. however it really is not noticeable from my listening spot.
My PrimaLuna preamp is dead quiet with 6 -12au7’s and a pair of rectifiers on board. And that is within an inch of the speaker drivers.
thanks. i am not sure what causes it, maybe the amps, as it has tube noise/hiss even with the preamp out of the equation.
I’ve never had a system that does not produce at least a little noise, but it has always been limited to ear-pressed-to-the-speaker white noise. This is not that.
I had / have hiss with SE into the BHK 300s. XLR DAC (not PS) → XLR Pre (not PS) → XLR BHK and it is dead quiet. I mean speaker on ear quiet.
SE I can hear hiss at the listening position.
I didn’t have hiss on my system before dropping-in the BHK. Changing power cables / power “strips” changed the amount of hiss but did not eliminate it. These amps love their balanced chains. Worth the extra effort / costs… I really like the BHKs.
Keep us posted if the new tubes in the pre do the trick.
Thank you, Brother James.
I received the tubes yesterday and let them sit open so they can warm up; it was a whopping 10 degrees outside yesterday. Because I have big hands I’m going to have to use needle-nose pliers to make the jumper adjustment. The blue transistor immediately above each jumper will present a challenge since their positioning does not give enough headroom for an easy jumper removal and reinsertion. By the way, your video on the subject was very helpful.
Thanks again
Eagerly waiting for an update.
Oh boy, I don’t envy the 10 degrees! Sounds great Jim. Keep us posted.
James and fellow big-handed Elk -
I managed to adjust the jumper back to 12V and insert the tubes James had so (amazingly) quickly sent to me. After an hour of warm-up I turned the volume to 70 with no signal passing through the system and the tubes were DEAD silent. By that I mean, I put my ear right up to the speaker and no hiss, no nothing. I then turned the volume down, put on an album and left the room for 25 minutes.
Flipping the album over and sitting down for a listen, I noticed no sibilance and a more defined center stage where, in classical music, a portion of the violists, the brass and the woodwinds are typically located. The tubes definitely need burn-in time, but I have to say now PS Audio matched the tube to the preamp expertly.
Thank you James and the rest of the brothers who help me resolve this.
YES!!! :grin:
Sweet! Great to hear my man!
