BHK Signature Preamplifier - Frozen screen after standby
Does anyone that own the BHK preamp still have issues with the screen freezing up after coming out of standby mode? It has been coming up on an intermittent basis (not so frequent).
A google search came up with the following explanation and potential solutions. In my case performing a hard reset (as outlined in solution 1 below) does work temporarily.
If your PS Audio BHK Signature Preamplifier freezes or locks up when left in standby mode—requiring you to power-cycle it using the rear master switch to bring it back to life—you are experiencing a known glitch rooted in the unit’s control microprocessor.
The Source of the Issue
The control board (the digital “brain” that manages the OLED screen, remote input, and relays) can occasionally crash or enter an unrecoverable state while the analog circuitry remains in a low-power state. This is rarely caused by the vacuum tubes themselves, as they are fully powered down while in standby mode. Instead, it is a localized freeze on the control board or a corrupted setting in the onboard memory.
The Solution Checklist
1) Perform a Microprocessor Hard Reset:
a) Turn off the master power switch on the rear panel.
b) Unplug the AC power cord from the wall/power conditioner.
c) Press and hold down the front-panel control button/volume knob.
d) While continuing to hold the button down, flip the rear master switch back to ON.
e) Hold the button for an additional 5–10 seconds. This forces the control microprocessor to clear its volatile memory cache and reload defaults, which frequently stops the standby freezing.
2) Disconnect the 12V Triggers: If you have 12V trigger cables running from the preamp to your power amplifiers (like the BHK 250 or 300), temporarily unplug them. A voltage leak or timing mismatch from connected equipment over the trigger line can trick the BHK preamp’s microprocessor into freezing up when it attempts to transition states.*
3) The “Always On” Alternative: Many BHK owners bypass this software vulnerability entirely by leaving the unit fully awake (“Play” mode) rather than using the standby button. Because it is a hybrid design, leaving it fully on will wear the vacuum tubes, but if you plan to do this, it is highly recommended to install a pair of long-life tubes or switch to an automated smart plug that drops the AC power entirely during extended downtime.
4) Check for External IR Interference: In rare instances, continuous ambient infrared (IR) pollution from plasma TVs, LED lighting strings, or faulty universal remotes can flood the preamp’s IR receiver while in standby, overloading the buffer and causing the control software to freeze. Try covering the IR receiver eye on the front panel with a piece of dark tape to see if the behavior stops.
I’ve not experienced this on my BHK Pre. I bought mine new in 2020. Wonder if your unit is older or younger than that or even if that matters. Also, you say solution 1 solved the problem for you temporarily. How long before it came back?
I bought the unit new in 2020. With regards to the frequency, I have not been observant!
Update: Since we have a plasma TV that’s somewhat in the line of sight of the door to my study when it’s open, I decided to try Step 4. I covered the IR receiver eye with tape and haven’t seen the issue recur over the past couple of days. Fingers crossed!
okay so I received my refurb yesterday and things got a little weird. First off i couldn’t get the remote to work. Turns out they sent me th wrong remote. Okay, they are sending me the right one. Here is the BIG issue. I moved the jumper to use some of my great 6922 type tubes and when I turned on the preamp everything was so LOUD and popping..whoa..turning the volume lower caused my amp to clip and cut off. WTF..so I double checked everything , same problem..tried another set of tubes same. Mind you I did reboot and unplug the preamp and let voltage leave each time. So I tried another set of vintage 7308 tubes but this time I disengaged the current jumper and all works and sounds fine. So why did this happen? I was told and watched the video that says to change the disengaged current jumper to on. Is the unit defective? Did anyone else encounter this?
You may want to reach out to PSaudio support!
