my statement is:
I want a one stop shop ripping and playing like a jukebox or CD carousel
Your store album and you listen new album by entity randomly or one after in order
None of this exist except old iTunes
For strange reason random playing is random songs only available
So instead of having 4000 album playing randomly you have 44,000 Song playing randomly (for me it’s a mess And unacceptable)I’m sor
This is a mess when you listen classical music or progressive music that one track slipped to the other to create a Masterpiece!
Spotify; Tidal; Deezer; Blue node; innuos; wmp; etc. Only do random song music
in iTunes music you have the choice of randomly playing Album or playing song
You could iTunes match and store all your Album and keep a copy on the cloud without any modification.
Apple Music, When you use it it collect information of your database erase your tag and replace by his, did the same with artcover, re format your music, loudness it, So you end up with a mess up database but it is cohesive for listening
I just want a simple device that replace my computer has a SPdif output, coax output analog output, and i2s output
No dac required, Just if possible on the device: a ripping; Push play; and a “soup du jour(random album)” Button. it have a HDMI output so I could hook one of old monitor on it to see the art cover of the album!
with or without streaming Integration for major streaming services
none of that exist only iTunes does that and you have to get an old Mac mini that have an IR in, it so you manage it with a simple Remote
Nothing like that exist anymore worst when you push “Play my song” you always end up with pop song that have absolutely nothing in common with your music
The only one so far that respect that is Amazon Music with my soundtrack!
But if your grandkid are at home and listen some Taylor Swift on your system on Amazon Music then your database is messed up for good! also good Amazon Music could integrate your music in your profile, so you will be able to listen to it.
I want:
Just a simple machine playing randomly the integrity of my Album. it play only the music she got on her hard drives!
Apparently there’s no market for that that’s why whim; Bruno node; innuos Don’t have this function on their device
