I have a question regarding this streamer. I hope anyone can chime in. The Cambridge has it’s own DAC but I like to connect it to my DSDAC is that possible? I suppose so, but just curious which input I’d best use: I have my PWTransport connected with I2S. The Cambridge does have it’s own DAC, so I may be tempted to check out that option too. Can I however use a balanced input on the DSDAC?
Just try both the Cambridge S/PDIF Coaxial and TOSLINK Optical outputs to the referred inputs of the DS, it will be worth it
(no balanced digital outputs on the Cambridge…)
@ wijber. Thank you!
