Can I use USB 2.0 Cat 6 extender to connect PC to DAC?
Hi.
The space in my room is limited, so my computer is positioned on the right side of the room. To connect my computer to the DAC while keeping the cables neatly organized, I need to route the cable around the sides of the room (and there’s a door), which requires a cable length of approximately 60 feet. Is it possible to use USB 2.0 Cat 6 extender, particularly this one from Lindy :
Anyone ever experience using USB ethernet extender ? How is the sound quality ?
I am using one now. PS Audio used to produce one, called the LanRover that advertised to improve sound quality. I haven’t done a direct AB comparison so not so sure, but I also use a USB DDC like the Matrix 2 or Innuos Phoenix to clean up the signal at the receiver end. Recently I found that I prefer the sound without anything in between so it’s all depends on your DAC and how good their USB implementation is.
