Can't play my flac files using Maestro
I have a Mac laptop with a full version of Maestro (love it!) installed and connected to my Musical Fidelity x-DAC. I don’t seem to be able to play my flac files in Maestro. I checked Maestro “Home Library” settings to make sure that the folder containing the flac file is visible. I have the Local Library option selected and it shows as green. If i click the scan local library option, my library folder is shown with a green circle next to it which should indicate that it is online. The folder name is: /Users/greghofer/Desktop/MusicFiles
If I go to that folder on my Mac, I have a file in there called: “Glinka - Russian and Ludmilla, overture.flac”
I then search for the music using the search function and it finds the file ok. I select the “play now” option and get a message saying “Couldn’t play this file”.
I downloaded the file from Qobuz after purchasing it from there. I can play it fine on Qobuz and on my Mac using VLC or other media players. Any thoughts on what is wrong or what I can try next?
Paul actively monitors the thread below, I suggest posting your question there. He usually responds early AM.
OK, thanks!
