Dimmer Switches
Part of the issue is what dimmer you use. I use a dimmer in the main sound room without any issue whatsoever. It works because of the dimmer I use which is a higher end Lutron that says it is "quiet". Indeed, all dimmers work by chopping the waveform but the better ones have a reasonably large filter inside that reduces the harmonics to almost nothing.
Yes, but if it is constructed correctly they should come with a 'zero-crossing chip' meaning that the switching is done when the AC feed is zero (i.e. 60 times a second).
frode said: 'zero-crossing chip'
Hmmm. Wonder if these are available in the USA?
Gordon said: http://www.ee.teihal.gr/labs/electronics/web/downloads/Light_dimmer_circuits.pdf
This is quite an article. Interesting.
For those interested, it addresses why dimmers make noise and the ways to address this in the design of the dimmer.
frode said: . . . the switching is done when the AC feed is zero
All dimmers switch at the zero crossing; this is how they work. :)
Yup.
In between the As and the Cs
This is the “cause” of the problems.
In 2013 I have to agree to this.
Here is one circuit:
http://pdf.datasheetcatalog.com/datasheet/motorola/MOC3042.pdf
What confuses me is that it seems that it is a non-zero crossing principle that is used in dimmers (random phase triac controller). If it switches under load, then noise is inevitable.
I believe you are correct. I did some reading and found that a random phase triac controller does not detect zero crossing and can remain on as the phase changes. This would create more noise than zero crossing.
Thanks for bringing this up - neat stuff.
