Direct Stream Junior/Gain Cell Dac Connection
What’s your opinion on connecting these two components?
Is it better to select HT Bypass on the Gaincell Cell Dac so that volume is controlled through the Directstream Junior, or standard connection using both volume controls. I have heard different opinions
Thanks.
