I have an old P500 Power Plant and it’s been feeding my DirectStream for over a year now. It just dawned on me that perhaps there’s a preferred MultiWave and/or Voltage setting that the DS may like. Does anyone have any suggestions? Maybe even Paul himself?
The only multiwave I routinely liked on my P500 was the one that adds some third harmonic to square of the sine wave. As it is the simplest, I bet it is multiwave one.
I find cleanwave the most interesting. It takes five minutes or so for the DS to settle down again after running cleanwave, but it then sounds better than before (I think).
Thanks! It takes some getting used to but I like it as well.
I am conflicted on this question only because it is so system dependent. Try it both ways. On my BHK I wind up using pure sine wave, but then on Stellars I use MW1. You’ll just have to give it a try. Do let us know.
