My Directstream JR to be dilerved on Wed… Am going to be using RCAs to connect to a Bryston BP25 preamp.
The Bryston XLR pinout is “Balanced inputs use 3 pin XLR female connectors with pin
1 being ground, pin 2 as positive signal, and pin 3 as negative
signal. Input sensitivity is 1 volt and input impedance is
15K ohms.”
Would this work with the JR, should I chose to go with XLRs instead of RCAs?.
Thanks and Happy New Year!
greyscale
That pinout is standard and PS Audio uses it.
You should be fine.
