To answer you question nothing changed, and this happened with both Jriver and Adrivana.
I reset the DS, unplugged and plugged the Audience USB cable, and nothing seemed to fix it, then 3 hours later it was magically working correctly again.
So I don’t have any idea what the issue was or how to replicate it.
If it happens again I’ll do it step by step again and see if I can isolate the issue.
Meanwhile I ordered an Isotone, recovery, and regen, to see what works best with my system, they all have reasonable return policies, so I’ll report back on my findings mid week. Using jitterbugs now, and plan to keep one in parallel.
sethmw said
The out come is good, the answer makes no sense...
S
Computer issues tend to be harder to isolate.
Did you disable up sampling? Did it work then?
If turning off to PCM didn’t work either, it could be just a handshaking issue over USB.
Sometimes it just needs a reboot of both the DAC and computer to get things working again.
If it worked on PCM/non up sampling, just not DSD up sampling it could be something else.
AFAIK, up sampling to DSD2x only works up to 5.6 not 6.1 so if the source was 48/96/192, you may be attempting to upsample to 6.1MHz.
