I HOPE this not humor, but… came home tonight, poured one, toggled on the gear, played a couple new tracks, nah, resorted to the old standards - uh uh, safety in the known favorite reference tracks…right?? I would swear someone came in to my soundroom during the day, adjusted all the tone controls I don’t have, moved the speakers, put a sheet of Christmas semi-translucent wrapping paper over the tweeters and switched the system to quasi-mono… After numerous moves of the Mags - I just gave up & shut it down.
I know Covid affects the taste & smell but the ears??
Anyone had nights like that??
oy-vey…
I fear it might be CBTinnitus… Charlie Brown’s Teacher-innitus…
Wah wrah - wah wah
And no cheap shots at my pikpen/pigpen nickname…
Seriously tho, the room was NOT RIGHT…
It’s why I stopped drinkin’…
Yes. Sometimes the rig just seems off for no apparent reason.
Next day all is well.
Something to ponder, for sure.
If you get three days in a row of “Meh”, I suggest you do some further digging.
It’s why I started!
Yep. Typically after a particularly crappy day pounding on the electronic grindstone for a minimum of 8 hours. Dealing with subcontractors good at breaking things, dealing with a government customer upset about everything while being partially responsible for everything it’s harping about. I can’t pour enough on days like that. The rig stays off as well. I’m absolutely convinced mental state, mood in particular, has a lot to do with my enjoyment of my gear.
Funny that you said this just now because I recently had an entire day feeling like my system had fallen off a cliff.
I looked at the variables on my P20 and everything was normal.
So I just pushed away from it and the next day my ears were back to normal. Sigh of relief…
I tried the clean system on P20. Sometimes that will clear up crap. I have also resorted to reload of Windom. Supposedly helps degaussing in the DSD and will set things right.
Interesting…
Sometimes, I wonder if a power outage might be funking things up, since I do most of my listening via the DS Sr. DAC. Maybe I should make a habit of making sure I don’t leave the Scan Disk pushed into the unit once things are sounding “right”. That way I am not getting inadvertent reloads of the Firm Ware, given the observed idiosyncrasies of certain Firm Ware loads. Thanks for the insight.
It usually would take around a hundred hours. I mentioned it in the Windom thread and Ted postulated could be need of degaussing that was setting it right. I leave SD card out too in case it mucks up the sound from power outage reload.
Well I know it happens to OTHER guys… but it’s never happened to ME before…
As I lower my head between my palms & sit on the edge of my listening chair in shame…
Tonight I’m gonna take 2 lil blue pills aurally and wait 20 minutes & try again…
I also think that - especially if you live somewhere it’s now winter, power randomness and static into your wires and gears can build up. Sometimes a manual, controlled power outage (including unplugging everything for a while) can help. Worth a shot.
That’s funny. My last job in the Air Force was as a combat communications engineer. We had a range of digital and analog systems we used to provide the communications pipe for a wing commander remotely deployed. Our equipment was broken as often as it worked. When we didn’t know why, “sun spot activity” always convinced the upper brass to back off.
Sun spots. Yeah, that’s the ticket. Sun spots.
I live in a 230v country. THD is never above 1, but voltage can be anything between 223 and 238! Before getting the P15, I used a Dectet and it used to trip like 2 - 3 times a day! The P15 never did it. Given that I have this wild voltage, and the fact that I have input tubes i the BHK pre, I opted for higher regulation in the setup, and this helps sound quality big time.
yep 235 up to 250 volt here in the uk…
P15 Specs.
Under Voltage Limit: Continuous -10% of setting 15 sec duration -15% of setting
Over Voltage Limit: Continuous 5% of setting 15 sec duration 10% of setting
So, you’re ok until 253 volts but only for 15 seconds.
