Fat feet under BHK250
Strange question; do they stick to the shelve when (re)moving the amp?
Both my Krell 222 and my Aragon feet tend to be sticky and I need to use some force to tear it off and lift.
The feet under the BHK may be even more sticky…? I will not move the amps often, however…
Cut out a small piece of baking paper to fit and put under feet at time of installation. Problem solved.
Thanks Brodric, Not sure if I have baking paper; but for now a piece of paper, seems quite simple and effective. Thanks!
