From P3 to P10
Hi, I’m writing from Italy, forgive me for bad english.
Are about 2 years I’ m enjoing a P3, and my system sounds so good as never before…
I’m so satisfied, that a little voice inside me is telling: “which improvement with P10?”
I don’t need more power, because my P3 display says I’m using only 300 watts.
I’m searching only quality sound improvement: do you think I could have it, passing from P3 to P10?
Thanks!
Hi, Sandro!
The P10 will sound better as the output impedance is lower, it has greater reserves, as well as other advantages.
The improvement will however not be as great as going from no PowerPlant to a PowerPlant.
(Your English is very good!)
I agree with Elk.
Thank you!
I just think I will take it…:wink:
I went from a Power Plant Premier to a P5 and then to a P10. There were improvements that I did not anticipate from each step up the ladder. I am confident you will really enjoy a P10.
lonson said I went from a Power Plant Premier to a P5 and then to a P10. There were improvements that I did not anticipate from each step up the ladder. I am confident you will really enjoy a P10.
Thank you lonson...
I’m sure I’ll be very satisfied.
