Anyone tried this on their PowerPlant and/or downstream components?
Thoughts? Effects?
Thanks.
Hi
Yes, i have one fitted to the new bhk pre amp. Reason being ive got hiss issues at the speakers. I purchased the above to see if it would do anything .but to be honest the hiss is still there. So its a little difficult to say it does owt. However when the volumes turned up, the music sounds great. Crisp clean through my pmc ib2 se’s. But it sounded good without it too. I think it cuts out frequency you dont really hear anyways. But like everything in this game, if you have it fitted, it makes me feel more happy, than not having it in the system.
Were you streaming? CDing? Vinyling? when you did the compare?
Thanks.
Streaming from qobuz. Via the solo a6 , the mk2 bhk, then bhk pre, over to my pmc , ib2’s.
