Fuse upgrades for Magnepans
Does anyone have experience with upgrading the fuses on Magnepan speakers? I recently traded my 3.7is on a pair of 3.7X. I’m very happy with the improvement but they use the same, inexpensive, glass fuses that were in the old pair. You’d think the fuses would be an obvious place for the X upgrade if there were benefits to be had. If you’ve played with fuse swaps on your Magnepans, I’d be interested in your impressions and what fuses you’ve tried.
Here is what I use in my LRS’
Thanks. What benefits, improvements would you say you are hearing with them?
My 3.7x’s have Synergistic Research fuses in them.
There are several different synergistic research fuses available. Which one did you use and what improvements did you hear? My local dealer said he didn’t think fuse changes would do anything. That is just his opinion.
They are the purple ones. Soundstage opened up highs smoothed out and the bass was more articulate.
Hey guys. Could you comment on the X improvement? Interested in what the X does as I’ve never heard the upgrade
I have .7s that I modified to the equivalent of an X model. It uses all film caps, 15 Gauge air core inductor and non inductive Mills resistor (I think the X still uses sand cast). No change to the wiring except bypass of the resistor attenuation post and fuse block. I also replaced the screw down cable posts with five way binding posts.
The most significant change is extended and more transparent mids and treble. Bass is a little less muddy. To my ears the speaker is improved by 15%. This is not a makeover but an appreciated upgrade. In my humble opinion the upgrade is not worth twice the price Magnepan is asking, but for $160 in parts and some labor it is worthwhile to do.
just an anecdotal comment… I had Maggie 20.1’s , had them for years… the issue was the minimal bass. I never got around to inserting a sub… they were sitting for a couple of years in the corner , mainly because I had a secondary set of other speakers we were using…i decided to part with them, in the weeks prior to their departure I had purchased an Airlens and a DS MK1 w transformer and VOCM mods installed… I pulled out the maggies and fired them up for the first time in years w the new equipment… when i played the Maggie’s my jaw dropped… there was a very significant amount of bass and overall clarity that I had not remembered… from an aural point of view. I would have gladly kept those speakers, (but the sale was pending)… From an aesthetic point of view…the imposing monoliths was something we (WAF) could no longer handle in the living room… Maggies are great, but the trade offs are there…unless you have the space…
I had my 3.7is for almost 10 years. I traded them on the 3.7Xs. The improvement is largely in the smoothness of the high end and mid-range. Sound stage and imaging were also improved. The difference is immediately noticeable. I’m very glad I made the upgrade.
as an owner of the Maggies, the MMG, 1.6. 3.6 and 20.1’s, I would never think of running them w/o fuses… for this advertisement to indicate that blowing fuses or tweeters almost never happens is , in my not so humble opinion B.S… use good quality fuses
I’ve been aware of that “upgrade” for a long time. I would never bypass the fuses like that. Since the synergistic research fuses are so expensive, I think I’m going to follow their advice from their website and start at the top of the chain. If I hear a difference, then I’ll work my way down to the speakers. I’ll have to look and see if there’s even a fuse in my Mark Levinson No.28. I know there isn’t one on the preamp itself. I don’t see one on the PLS-228 either. Maybe they are internal. Nothing about fuses in the manual either.
