Just curious if anyone has tried the new’ish LAiV Harmony µDDC Reclocker with their DirectStream MKII and if so the impact it had?
Yes, have the DDC between my streamer and MKII, I2s in and I2s out. There is a difference, positive, however, nothing ground breaking in my system.
Oh forgot, also coax in from CD, also positive.
@wudai_e Thanks for responding, I almost didn’t ask out of fear no one would answer! Did you have to fiddle with the i2s settings at all to get compatibility between the two devices?
thinking of getting one to connect my Innuos (and other digital sources) to my LAiV dac. Weng Fai told me that since the Innuos is USB the difference could be minimal. For other sources it will be more.
No, Laiv adopted PS Audio’s default as their pin mapping.
