How Important Is System Synergy?
After decades of listening, countless component changes and many audio shows, I’ve come to believe that specifications, reviews and the quality of individual components only tell part of the story. A great system isn’t simply a collection of excellent products. The final performance of a system depends on how those elements interact.
I suspect many of us mean slightly different things when we talk about “synergy,” so I’m interested in how others define it and whether that definition has changed with experience.
To me, true synergy is about creating a chain where every component supports the strengths of the others. The goal is not to correct flaws, but to achieve a balance where the system behaves as a unified whole, with each part allowing the others to perform at their best.
This principle does not apply only to ultra-high-end systems. In many ways, thoughtful matching is even more important in modest systems, where choosing complementary components can often bring greater improvements than simply spending more money.
Synergy is not a universal formula. The same combination of components may be perfect for one listener and less convincing for another. Personal taste, room acoustics, listening habits and musical preferences all influence what feels natural and coherent.
Like many enthusiasts, I initially approached audio one component at a time. Each upgrade brought obvious improvements—greater resolution, deeper bass, better imaging or more detail—but each also revealed another area that seemed to need attention. In my experience, the real performance of a component only becomes apparent within the system and room in which it operates. The systems that remained satisfying after months and years were not necessarily the ones that created the strongest first impression. They were the ones that invited long listening sessions, continued to reveal more over time, and behaved as a single musical instrument rather than a collection of individual components. To me, an endgame system is one where the musical reproduction is so convincing that further upgrades become far less important than simply enjoying the music.
As my system became more revealing, it also became clear that the environment was inseparable from the equipment itself. Power delivery, digital infrastructure, mechanical isolation, room interaction, loudspeaker placement, listening position and thoughtful acoustic treatment all played a role. None of these elements transformed the system on its own.
A highly resolving source can sound analytical in one system and completely natural in another. A tube amplifier can bring beautiful harmonic richness, but it can also make a system overly romantic if it is compensating for weaknesses elsewhere.
Even an excellent loudspeaker can fail to deliver its full potential if the electronics, room and other components are not working together.
The key, for me, is that every component has to be chosen according to how it interacts with the room and the rest of the system, contributing to overall system coherence.Although this approach seems simple, it turned out to be quite tricky. Selecting components based on exceptional reputations, impressive measurements or outstanding reviews turned out to be insufficient. Like many others, I made several wrong decisions before finally arriving at a combination that worked for me.
The biggest change in my approach was not technical but philosophical; after years of upgrading, I eventually realised I had been searching for better equipment when what I truly needed was a better relationship between the components.
One example that helped shape these conclusions is my current system:
  • The dCS Vivaldi Apex DAC and Upsampler, whose transparency and timing provide the foundation for the system’s presentation;
  • The TAD E1TX-K loudspeakers, whose ability to present music as a unified performance rather than separate frequency ranges complements the rest of the chain;
  • The Audio Research REF160S, whose tonal balance complements the precision of the digital front end without sacrificing musical coherence.
For me, together these components create a system in which the whole is greater than the sum of its parts. I can listen for hours without fatigue. The equipment no longer demands attention; it simply allows the music to exist.
I also spent considerable time evaluating an ARC REF6SE preamp which brought qualities that were undeniably impressive. However, removing it ultimately produced a presentation that I found more coherent. So I chose to connect the Vivaldi Apex directly to the REF160S (not because I believe preamps are unnecessary, but simply because it illustrates how synergy depends on the interaction between specific components in a specific system).
Ironically, the closer the system came to genuine high fidelity, the less I found myself thinking about high fidelity itself. Instead of analysing bass, imaging, or resolution, I became increasingly aware of the relationship between musicians, performances, and recording venues. The emotional intent behind a performance became easier to appreciate. Familiar recordings continued to reveal new details—not because the system exaggerated information, but because it presented the music in a more natural way.
I went from: “How good does this system sound?” to: “What album should I listen to next?” A good audio system impresses. To me, a truly exceptional one disappears.
I would be interested to hear how others approach system building. Has your definition of synergy changed over time? Do you believe synergy is something you can predict from specifications and reviews, or is it something that can only be discovered by listening? Has your approach to system building changed as your experience has grown?
Intriguing thread and interesting approach.
My path has been similar. I’ve been unable to treat rooms so the quality of the room influences how the system presents and influences my choices.
I found over the decades that I love tubed equipment, lower powered amplification and the single ended topology. Matching amplifier and speakers is important and I found a great complementary presentation using Decware’s HR-1 speakers and finally their 300B amp–it has the right amount of power and not more, and a great smooth and detailed presentation results. My VooDoo Cable Stradivarius interconnect cabling is well matched by the PS Audio AC-12 power cabling I use, their strengths matching their limitations well. The Decware ZROCK3 is the perfect component for me to dial in just the right variations in tonal balance. And none of these has ever been revealed as the weakest link, each improvement in source components (where I think it all begins) has been appreciated and only money has kept me from climbing another rung on the ladder to the very best.
I have arrived at a complete system that satisfies and has a welcome balance of detail and musicality.
I believe whole-heartedly in synergy. At the same time, I have found the term reduced to a level of almost being irrelevant since moving to a single-box approach. And I also believe fewer components + DSP is the future.
“Irrelevant”? Wouldn’t a single box be the ultimate example of system synergy?
Yes Ron. My reply was perhaps awkward. The point I was making, is that the sometimes perhaps psychological concern over synergy completely disappeared in my case when I moved to a one-box solution, when all I had to “worry” about was speaker cables and speakers.
Plus my believe that true Hi-Fi is moving towards this goal, whereas separates will survive only for those with very deep pockets.
But, I think we may be observing someone with seemingly unlimited deep pockets converting to a fewer-box approach right now in almost real time. :grin:
I’m rambling now, I know. But I’m thinking along terms like “the way of the dodo”; and to use a vehicle analogy - it seems the writing is on the wall for so-called “German Tech” vs what is coming from China at the moment. Likewise for Hi-Fi.
Be it as it may, I’m speaking ONLY for myself when I say “synergy” has become irrelevant since I’ve “downgraded” (not!) to the Aurender AP20.
Great food for thought. Thanks for sharing your “journey” in such detail.
Mine started a long time ago after I heard my first electrostatic loudspeakers the Acoustat Spectra-22’s. They were like nothing I’d heard at the time and I then chased feeding them better power. This lead to a Electrostatic Amplifier made by Innersound. Then the Acoustats were replaced with Innersound Eros hybrid 'stats which lead ultimately to Sanders Sound Systems Model 10e hybrid 'stats and (2) Magtech amplifiers and related dBx Venu360 DSP LMS.
So most of the initial focus was on the “back end” speakers and amps, but there was a parallel journey later that involved getting back into vinyl around '08 and discovering Rega products. I’ve also spent quite a bit of time improving my digital front end with various separate CD transports and DACs.
The current setup is so satisfying that music has become the focus and that just feels like a perfect finale to all this development work. It’s been decades and lots of study but really mostly a very fun “hobby” that as we all know can get very out of hand financially and can consume vast amounts of time. I’d call this a “healthy obsession”.
I built a massive system, it seemed nice. Now I am testing to see if I can replace it all with active speakers and sources. No Amp, Preamp, speaker cables. None of that. Just active speakers and sources. (3, Turntable, CD player, and most likely a $500 laptop and Maestro).
Synergy isn’t something I have ever thought too much about. I did buy a Gryphon amp, preamp, cd transport DAC, and power conditioner. I almost bought speakers from them. I guess I got Synergy the easy way. One major source for most components.
The PMG guys know what I’m talking about.
Amplifier + speaker + source is simplification
source + speaker + amplification in one box, is synergy! Naim try that Future-Fi!
how does it sound, I don’t know but it does the job!
this is integration…!
Also Darko Audio, talk about new Kef eggs that are small and efficient and does all!
PS is about in 2027 to bring, all in one bookshelf speaker [Black hole, they will absorb all source of energy to produce synergy!]:wink:
From what I understand, it is a musical approch and less HiFi approach!
Amazing as it is, why are we stuck with a minimum of 2 speakers for HiFi? with all developpement in computing, nobody produce a software that eliminate that?
why are we still need 2 speakers for listening: one pianist; one saxophonist; one drummer; one base?
it should be easy with A.I. with only a huge speaker to phase all that and sound in stereo or more accurate produce a 360 sound? you put it in the center and computer calculate the sound and place image in the room!
Saw cloud atlas a few week ago, the girl enter a room, it’s all concrete and gray, He turn on the computer and suddenly it became a room with everything! to my understanding this is future! and also with one source and some phasing, we will in a few years from now go to one source and 360 sounds, the ball game will be in computing and accuracy of electonics + drivers and programming!
PS Beatles record and manage there recording all the way up to the mono version! after that engineer goes in and mess up to do a stereo recording!
Many many decade ago, has student to pay my study, I was working and selling HiFi. A man came in order one Quad Mono with a mono cartridge for is mono Lp12 and one mono GRF corner Tannoy! that it. When I ask why, his answer : I am the one who pay for it, just order it and he pay upfront and invite me to listen the gears after it was install. he was sitting in the corner facing the corner the mono Fi, was install, and the music fill the room, like nothing I heard after that. None of my HiFi experience was better than that! with is good recording!
ps bass on record is recorded in mono, because, if not, the needle will go all left or all right!
So what’s next! a mono 360 computer generated sound to fill the room and 3D space management! that will be future! the one that achieve that will get the market! This is the Future-Fi!
My amplifiers and preamps all come from the same company. The amps all come from the same brain. The preamps all come from the same brain. The cables all come from the same group of brains. The speakers the same. It all works to make me very happy. Synergy can be your friend.
Sometimes, it is tempting to go that way and just focus on music and turntable for my memorable record stack over the years!
but I am ripping them for my car, so maybe, I won’t need a turntable!
