Interesting Articles
I then asked about this next combination………
Yes, the PS Audio BHK 600 power amplifier is an excellent match with the PS Audio FR30 speakers. Here’s why:
1. Power and Headroom:
  • The PS Audio BHK 600 delivers 600 watts per channel into 8 ohms and 1200 watts per channel into 4 ohms.
  • The PS Audio FR30 speakers have an impedance of 4 ohms and are designed to handle high power with ease. The BHK 600’s wattage should more than suffice to drive the FR30s with ease, even in larger rooms or at high volumes, giving you plenty of headroom and effortless dynamics.
  • The FR30s are highly sensitive and efficient, so they can deliver a large amount of output even with moderate power. However, the BHK 600’s extra power ensures that you have plenty of control over the speakers, especially when dealing with complex, dynamic music or large-scale orchestral pieces.
2. Synergy Between Components:
  • Both the PS Audio BHK 600 and PS Audio FR30 speakers are designed by the same company, so they are engineered to work together seamlessly. PS Audio focuses on creating products that complement each other in terms of sound signature, performance, and reliability. This synergy should result in a balanced and cohesive sound.
  • The BHK 600 amp, being a hybrid design (tube input stage and solid-state output stage), offers a warm and musical character with excellent transparency and clarity. The FR30 speakers are known for their precise and detailed sound with an expansive soundstage, so the pairing should deliver a natural, engaging listening experience.
3. Sound Characteristics:
  • The BHK 600 offers a rich, musical sound with some tube-like warmth, making it great for long listening sessions. The FR30s are highly accurate, transparent, and dynamic speakers with excellent bass extension, so the BHK 600 will complement these characteristics by delivering the necessary power and warmth without sacrificing clarity.
  • The combination of the BHK 600’s detailed low-end and the FR30’s ability to resolve fine detail means you’ll experience a full-range, highly dynamic sound with great depth, imaging, and a natural sense of space.
4. Room Size:
  • Given the BHK 600’s power, this pairing is ideally suited for medium to large rooms, where the FR30s can stretch their legs and perform optimally. The BHK 600 has more than enough power to fill a large room with ease, while the FR30s are designed to handle it without distortion, giving you a robust and dynamic performance.
5. Control & Precision:
  • The BHK 600’s high power output allows for tight control over the FR30s’ bass, ensuring that the low frequencies are clean and well-defined without being muddy or overbearing. This makes it an excellent choice for audiophiles who enjoy full-range music, including bass-heavy genres like electronic music, jazz, or large orchestral compositions.
6. Build Quality and Reliability:
  • The PS Audio BHK 600 amplifier has a solid build with an ultra-low noise floor, excellent construction, and reliable performance. The FR30 speakers are similarly well-engineered, built with high-quality materials. Since both components are from the same brand, you can expect them to work well together and provide years of high-performance listening.
Conclusion:
The PS Audio BHK 600 power amplifier is an outstanding choice to pair with the PS Audio FR30 speakers. The combination offers plenty of power, excellent sound quality, and solid synergy between the components. The warm, detailed character of the BHK 600 will bring out the best in the FR30s, and you’ll have an immersive and satisfying listening experience. Whether you’re listening to delicate acoustic music or large orchestral arrangements, this pairing should perform beautifully.
And while I was there, I typed in the next combination…….
Yes, the Gryphon Diablo 333 is an excellent match with the PS Audio FR30 speakers. In fact, it would make for a very high-end, dynamic, and precise pairing. Here’s why:
1. Power & Control:
  • The Gryphon Diablo 333 delivers 333 watts per channel into 8 ohms and 666 watts per channel into 4 ohms, making it a powerful amplifier capable of driving demanding speakers with ease.
  • The PS Audio FR30 speakers have an impedance of 4 ohms and are designed for high power handling, with sensitivity around 87 dB. This means the Gryphon Diablo 333 will be more than capable of providing the FR30s with all the power they need, delivering full control over the speakers, especially in larger rooms or at high listening volumes.
2. Precision & Musicality:
  • The Gryphon Diablo 333 is known for its precision, transparency, and musicality. It strikes a balance between the highly detailed, neutral, and transparent sound often found in high-end solid-state amps, with a smoothness and musicality that makes it easy to enjoy for long listening sessions.
  • The PS Audio FR30 speakers are designed with an emphasis on transparency, dynamics, and clarity, and they perform well across a wide range of music. The Gryphon Diablo 333 will bring out the best in these characteristics, offering deep bass control, lifelike midrange clarity, and a wide soundstage.
  • Gryphon Diablo 333 amps have a reputation for having a slightly warm, yet neutral sound profile, providing an engaging listening experience without being overly analytical or sterile. This should pair very well with the PS Audio FR30s, which are detailed and highly transparent.
  • The FR30s are known for their extended low frequencies and articulate midrange, so the Gryphon Diablo 333’s ability to control the bass and provide smooth, distortion-free power should allow the FR30s to perform at their best, particularly in the lower frequencies where some other amps might struggle.
  • In the high frequencies, both the Gryphon Diablo 333 and the PS Audio FR30s should shine, with excellent extension and smoothness.
4. Synergy Between Components:
  • Gryphon amplifiers are typically very versatile and can match well with a wide range of speakers, especially when it comes to resolving fine details and creating an expansive soundstage.
  • The PS Audio FR30 speakers are engineered to be highly revealing, with a focus on accuracy, and they can benefit from the Gryphon Diablo 333’s ability to drive them with exceptional control. The pairing will bring out the speakers’ full potential, especially in terms of transparency, imaging, and dynamic range.
5. Room Size & Listening Levels:
  • Both the Gryphon Diablo 333 and the PS Audio FR30 speakers are well-suited for medium to large rooms, where they can perform to their full capabilities. The Gryphon Diablo 333’s power output and the FR30’s efficiency make this pairing great for larger spaces, where the speakers will benefit from the ample power and the smooth, controlled output of the amplifier.
  • If you tend to listen at higher volumes, the Gryphon Diablo 333 will easily handle transients and peaks without distortion, while the FR30s will maintain clarity and precision in the bass and midrange.
  • Both brands—Gryphon and PS Audio—are known for their excellent build quality. The Gryphon Diablo 333 has an incredibly solid, robust construction, and PS Audio FR30 speakers are built with top-tier materials. This not only means reliable performance but also a long lifespan for your system.
The Gryphon Diablo 333 is a highly regarded amp in the audiophile world for its quality, design, and performance, and it should provide years of high-performance listening with the PS Audio FR30 speakers.
7. Room Interaction & Acoustics:
  • The PS Audio FR30s are known for their large soundstage and detailed imaging, so room acoustics can have a big impact on their performance. The Gryphon Diablo 333’s accuracy in power delivery will help mitigate any room-related distortion and give the FR30s the precision they need to shine.
  • If you haven’t yet, I’d recommend considering room treatment (like bass traps or diffusers) to ensure the best performance from the speakers and amp combo.
Conclusion:
The Gryphon Diablo 333 is a fantastic match with the PS Audio FR30 speakers. You’ll get the power, control, and finesse necessary to unlock the full potential of the FR30s. The combination should deliver a very detailed, engaging, and dynamic sound with excellent bass control, a natural midrange, and crystal-clear treble.
This pairing would be ideal for audiophiles who appreciate precision, transparency, and musicality. The Gryphon Diablo 333 will drive the FR30s with ease and provide a rich, immersive listening experience across a wide range of music.
Maybe it is me but I am beginning to believe I spend too much time here….
A Glorious Place for Music
https://www.nytimes.com/2025/09/23/arts/music/moab-music-festival.html?unlocked_article_code=1.oU8.H6iE.PzGvWWsgURUW&smid=url-share
Geez. So many brands under the Harman umbrella (Samsung).
Harman Closes Sound United Deal
So far, they seem to be managing it well. Let’s hope it stays that way.
I’ve been asking ChatGPT a lot of similar questions lately, and some of the answers have really surprised me. What’s been most interesting is the level of detail it gives when you provide full room information. It doesn’t just stop at general advice—it goes all the way down to recommended starting dial settings for subwoofers, placement suggestions, and even lays out a multi-day plan for testing different positions. I was impressed that it could guide me step by step through setting up a stereo pair of subs.
A brief few thoughts about future possibilities for preserving digital information in more durable media
https://physicsworld.com/a/father-of-the-internet-vint-cerf-expresses-concern-about-the-longevity-of-digital-information/
interesting article on the first 192kS/s recordings. The article is on page 79.
https://www.worldradiohistory.com/Archive-All-Audio/Archive-Studio-Sound/90s/Studio-Sound-1997-08.pdf
Bowie’s legendary Hi-Fi system returns as an exceptionally limited edition | T3 Bowie's legendary Hi-Fi system returns as an exceptionally limited edition | T3
https://www.stereophile.com/content/mbl-gains-new-owner-says-future-secure
mbl has a new owner, says future is secure.
I wonder how long before production is moved to China?
Thanks, interesting read (I was fairly heavily involved in a couple of recording studios by 1997).
Also interesting was the article earlier in the mag on the BBC recording Glastonbury bands etc. - how the beeb moved on after this time with, by the 2000s, live feeds from 5 or 6 stages etc. :slight_smile:
I didn’t notice that article. Thanks!
I’m not sure what to think about all this AI business but I at least feel less ignorant. Interesting summary and link to a 3 episode Longview podcast.
Study reveals that listening to music may reduce dementia risk in older adults https://share.google/41aTlLFHigcp898Pp
So I can start using my HSA to buy gear at a marginal rate discount?
Not 100%. Just ask my friends.
Are any of them young enough to remember you?
