Is there an Optical (toslink) to USB B, AES/EBU or COAX adapter?
Looking at adding a ddc to my system which will work as a source switcher (I have 2 sources with i2s, 2 coax and toslink, a couple AES/EBU, one with Datalinque (Theta) and one with toslink only. The DDC i’m looking at does not have a toslink input.
Is there a good low noise/artifact converter?
EDIT: could be to AES/EBU or COAX
This is USB-A
Hifime SPDIF Optical to USB converter, record DAT/minidisc to computer
The Wyred4Sound Remedy is a great s/pdif converter (really good clocking).
