I bit the bullet and bought a Lumin U2 Mini for my system. I have a PerfectWave DAC and I’m feeding it with coaxial input. The stream seems to work fine, my issue is with the Lumin app you have to use to control it.
I’m 75 so I’m not really good with iPhones or iPads (very bad eyesight) so I picked up a M1 MacMini to replace my aging 2012 MacMini. I feed the Perfect wave with USB from the old MacMini and everything works fine; I just wanted to see if the Lumin would give me a little more.
I’m using an external drive on the M! MacMinito give me room for the thousands of tracks I have on file. Up until now I’ve used Swinsian to control the music, it works well with any music format I’ve tried from mp3’s to hires 24 bit files.
The M1 recognizes and runs the Lumin app fine, the problem is that app is about as obtuse as anything I’ve seen in decades. It wants nothing to do with the 10,000 files on my disk, it will connect to Qobuz or Tidal fine but the interface for that is balky at best. Lumin suggests I use MinimServer as a DLNA server so I downloaded and tried to ue that. It seems that requires JAVA but the M1 and Monterey want nothing to do with JAVA. Funny how a $25 piece of software runs circles around the Lunin and it’s control software ($2400).\
I’ve requested a RMA to send the LUMIN back.
