I am relatively new to PS audio and the higher end of HiFi. It has been great reading and confusing myself in this new to me hobby.
At this time I am running these M700 mono blocks and have been reading how a lot of you have upgraded your power cords. So I thought I would do the same. I found myself a great deal on AQ blizzards. After making sure with a dealer online that these would fit. I pulled the trigger. To my surprise when I received these cables. They are 20A IEC. With a C19 end. This end does not fit as amps are 15A. Arg!!.
I’ve seen 20A male IEC to replace the ones in the M700’s.
Is this a desirable upgrade for these amps sound wise ?
Is this upgrade going to bit me financially in the future if I re sell them?
I did the same except in the opposite direction. Years ago I purchased the VooDoo silver 15A to 20A converter to power a Shunyata Hydra 8 also to good effect. Although their silver-wired converters are getting closer to the price of the Shunyata and their copper-wired version might serve you well.
Thank you for the feedback guys.
I was thinking this way as well with an adaptor. That being said I’m in Ontario Canada. I D on’t seem to be having much luck finding said adaptor.
