I am thinking of bi-amping my JBL’s. Going from a pair of M700’s to two S300’s wired vertically, one each channel. I have a electronic crossover so this would eliminate my passive crossovers. Any thoughts?
Thanks, Roger
Hi @kline42
The M700s sound is quite different. I would start with bi-wiring using them and listen.
If you’re adamant about biamping why not two more 700’s buy used if you’re on a budget
Agreed. I’d stick with the M700s and just bi-wire them if needed. I prefer the sound of the 700s a fair amount more then the S300.
