Modding the DirectStream DAC MKI
When you do the VOCM mods, are you using a surface mount tantalum, or a much larger through-hole electrolytic cap?
Am I correct in thinking that the larger through-hole 'lytics are probably easier to mount onto the surface mount resistors than are the surface mount tants?
A post was merged into an existing topic: For Sale: Fully Modified Directstream DAC sr. with external power supply and LL1948 transformers like NEW
Your post was just removed/merged with marketplace post, AFAICT.
Yep. the Marketplace is the proper location for ā€œfor saleā€ posts.
This thread is for discussing any and all mods to the DSD.
A fully modded DAC with photos isn’t a mod discussion?
OK
Fixed
Not when it is a detailed ā€œfor saleā€ post. :slight_smile:
Your decision to delete a good number of your other posts in this thread does not appear to fix anything and is unfortunate, but we trust our members and allow users complete control over their posts. So it is your call.
I however encourage you to reconsider and to restore your posts. I suspect they are of interest to a good number here and unrelated to your decision to sell your DAC.
Encourage isn’t strong enough for me. I am begging you.
It seems Jeff’s account isn’t allowing PM’s or @'s.
I exchanged a PM w/ Jeff about 4 hours ago.
FYI.
I can no longer PM him. The Message button is gone.
:man_shrugging: :man_shrugging: :man_shrugging:*
*3 character minimum.
:wink:
But wait, now I am up to like a gazillion characters!
Overachiever!
I don’t notice a decline in SQ.
Just a blacker background on every step.
After applying termination of the inputs:
-USB
-HDMI 2
-SPDif
-AESEBU-XLR
Is there a mod that will give the DAC a bit more air? Currently I wish there was a little more air and bass impact.
Here’s a list of mods that includes the posting number associated with some info about each.
Welcome to the Forum @driftingbunnies.
thanks! I’ve definitely seen many of the posts with different mods but it’s hard to keep track of what does what lol. Didn’t know if any of the mods helped with air and bass impact in particular
Unfortunately, that’s going to be super subjective based on the rest of your gear.
There’s several mods that should go together and there’s some that can be done alone.
If you want to try something on the easier side take a look at the recent postings regarding USB and I2S shorting plugs.
Did you have more air from another source component in your setup before or do you just desire more from the DS?
I just want to find out if you’re sure your setup will show more if it’s available.
All I’ve done is swapped out DACs once getting this directstream. I’ve updated to Sunlight. I’ve used Violectric V800, NAD M51, Abbas, auditioned TT2 to name a few. I feel like the directstream is a little darker with less airiness and impact. Adding those would make it a killer DAC for me.
