Good point.
Any questions or correspondence for me please use the other forum. Iâll be hanging out there.
Thanks!
Going to miss you, JeffâŚ
I hope you reconsider, in time.
Cheers.
You dont have to leave, you can visit two forums.
Iâll pop in from time to time.
Thanks.
JK, I meanwhile tried 6800 and 8200 pF with the Lundahl. Although one wouldnât think, as it affects above and slightly under 20 kHz, it makes a big difference. 6800 pF is too much top extension/level and sounds artificial with several recordings, 8200 is a better choice brings back an always natural top end and presence region but still is a tiny bit too little open.
I think you were right when saying, 7800 pF is probably optimal, but you mentioned that this value is hard or not to find as SMD partâŚis this correct or do you know any that could be used?
FYI. In case anyone decides to make this âheat sharingâ mod on the PS heat sinks thereâs no need to electrically isolate between heat sinks. The devices all have insulating shoulder washers and pads. I also checked that the (4) heat sinks are already electrically connected together so the aluminum plate bridge can be installed without any electrical insulation. You may wish to include a thermal pad under the plate for better heat transfer, but the #4-40 screws do not require the shoulder washers shown in your image.
Thanks for making this suggestion. Iâve just installed the nickel transformers and want to reduce the operating temperature on the 12V regulator.
Best,
Kurt
This is not the best way to do the heat sinks. That flat plate is blocking the fins.
I found this works best.
Have added several more holes in my heat spreader. Done with mods for a while I think.
Did you get your Vocm mod finished?
Hi All,
Iâd like to chime in on kcleveland123âs desoldering station recommendation. I bought one and used it to successfully replace the stock transformers with the 4400s. I figured out how to easily remove the collection tube for cleaning, which people complained about. I also figured out how to use the cleaning rods to clear the collection tube when it gets blocked with solder after almost every trigger pull. After all that, I successfully replaced the stock transformers with the 4400s.
A couple of weeks ago, I decided to perform the 1:2 mod on the 4400s, which requires me to remove the transformers. The first thing that happened is that my trusty ZD-915 got clogged up and I couldnât unblock it using the cleaning rods. To solve the problem, I purchased a 6â-1/16â drill bit and drilled it out, which works great. However, I have to do it after each trigger pull and the bit will only fit inside the largest tip (nozzle) I have, which isnât the one I used initially. I used the medium one. After all of that, I canât get the 4400s back out to perform the mod.
I purchased the ZD-915 for $140 because I didnât want to spend $324 for a Hakko FR301-03/P. When the ZD-915 got clogged up and I couldnât clear it initially, I decided to check out the 1-year warranty. There was no company contact information in the documentation sent with the product, on the Amazon web site, or on the Internet in general. I contacted Amazon and they couldnât find the company contact info and they refused to honor the 1-year warranty. In the future, I wonât purchase a product if I canât find any company contact info. As the old adage goesâŚyou get what you pay for.
If itâs like the inexpensive model I used (borrowed) itâs important to let it warm up properly, for a few minutes after it achieves the desired heat. This heats up the entire path to the collector so the solder doesnât go solid halfway there. It pays to rtfm
I have the Hakko. Two things: 1) Make sure itâs heated all the way, let it heat up for a few minutes; 2) When done with the extraction, move off of your work keeping the trigger pressed for a few more seconds.
Have fun!
vkennedy61, thanks for the suggestions. Can you please tell me what temperature you use when you extract transformers using your Hakko?
2.5 on bottom wheel
Whatâs the purpose of that blue insulating material which looks like it is being used as a separator for the heat sinks in your picture? Since you are electrically connecting the heatsinks together with the wire, insulating them from each other doesnât make much sense to me.
If you read the post carefully it states these are heat sink material for M,2 drives. They transfer heat not insulate.
Thank you very much. I assume that translates to 425 C. jkrichards 4400 1:2 mod attempt two coming up
