If we had a shield of its own concentrically around each signal conductor, each connecting to the source end, and had also a “main” shield concentrically around the lot of those, would this act to shield the signal wire from ground noise more, with two layers of essentially the same shield as cover? If the outer larger concentric shield has over twice the surface are of the signal-wire-concentric shields, would it act to lead noise to source ground “before” the inner shields are affected capacitively much at all, giving clean grounds surrounding the signal wires?
Separating the signal conductors with their own shield tubes decouples them capacitively, no?
What about leading all signal grounds to their separate grounding box(es)?
