I am having a problem with the speaker spikes on my Olympica II speakers. If I set them up on my floor, get them tightly against the floor, with the top caps screwed on tightly, within 24 hours one of the rear spikes already has a small gap between the spike and the floor, enought to affect the imaging/soundstage. If I then tighten it again, within 24 hours, there is already again a small gap between the same spike and the floor.
You can also use clear (or any color) nail polish to before trying Loctite. It works and easier to undo and you can try small bits at a time. Easy to break it open and heat from hair dryer helps the process if needed.
Since these speakers are very heavy and I’ve never used loctite before, I’m thinking of trying a split lock washer, nordlock washer or a serrated lock washer. Any idea which of these would work better or if they would work well at all? It would be the easiest and fastest fix for me to try.
I do not think teflon tape, no matter how little you use, will allow the two parts to thread together. Plumbing threads are course and allow such things. Speaker feet have finer threads that don’t allow clearance for the tape.
George, if you just used a wrench to carefully tighten your cap you would probably be fine. I don’t believe fingers are the correct tool.
A little Teflon tape or hemp might help on the threads. Carefully tightening with a tool, as Al mentioned, is easier than using bare hands.
But be careful: If you tighten it too much, it might even break.
Use wider jaw Channellock pliers or similar with a thinner piece of leather which will help grab and tighten with less chance of a prairie fire amygdala incident.
Blue Loctite vs a lock nut - which is more secure?
I don’t currently have enough space to add a lock nut, but I plan to try and figure out a way to make the space - unless Blue Loctite is as good or better at keeping things tight.
