Newb xlr question, mogami platinum okay?
I am upgrading my father’s sound system to a gaincell preamp/dac amd dual m700 mono amps. I have vintage Polk SDA SRS 1.2 loudspeakers and dual JL Fathom F113 subs. I’d like to use the CLR connections, which we’ve never used before, from the preamp to the m700 amps, then rca outs from preamp to JL subs.
It seems to me that the Mogami platinum CLR would be sufficient and budget friendly. They seem to be for recording/microphones over their gold series. Would they be good for my application? Thank you so much, I’m very new to this stuff.
Welcome!
Mogami is good quality, a great place to start.
Thank you so kindly
