Ohms my G...? 16/11/8/4 or ...2?
someone ask me a question, and I’m not sure the answer is:
Does a 4 ohms speaker, Would damage a 8 Ohms amplifier?
Does a 11/16 ohms, Would damage 8 ohms Amplifier?
what do you think?
A 4 Ohm speaker don’t destroy anything but if you had a 2 or even a 1 Ohm speaker, Infinity Kappa 8 and 9, it could start to burn depending on how your amplifier is constructed.
A 8 ohms Amplifier is ultra-secure from being damaged by a 11/16 ohms speaker.
thanks, So the lower They are the more problem you could have so I better have 4 Ohms to make it work!
4 Ohm is twice as hard for the amplifier than what 8 is and 2 ohm is 4 times as hard for the amplifier than what 8 is so yes, the lower the ohm is the more problematic it is for the amplifier.
So better found a tube amp, with 4 Ohms than!
Dali Kupid are 4 Ohms and bookshelf and 83db efficient!
So won’t work on a 300B at 8watts?
I have to find something else for him!
83db speakers are very low sensitivity so I doubt small tube amps would work in any normal sized room. Many tube amps have selectable impedance, usually offering a couple of difference impedances.
one last:
4 Ohms amps on 8 Ohms speakers?
I don’t know what you mean with a 4 Ohm amp since that don’t exist.
Even if a loudspeaker says it is 8 ohm it COULD destroy your amplifier.
Infinity Kappa 9 SAYS it is an 8 ohm speaker but that speaker goes BELOW 1 Ohm in the deepest bass so to bee sure how a loudspeaker will affect your amplifier you must figure out what the lowest impedance that speaker goes down to is.
good morning
Apparently you never change the Hi-Fi in your car!
Most car HiFi working for 4Ohms For Louder result!
:wink:
and here wiim spec:
So good those Dali Kupid, I have bought a pair for myself they did a superbe job on el84 4 Ohms
i hope i will have same result on 300B
one day delivery Azon 6 color of choice
they really nail it!
and affordable/cheap those Danish speakers!
they replace my Tannoy!
still waiting Ps powered bookshelf!
