So, I listened into the wee hours of this morning (way too late) - after installing 2 iQSEs into the Direct Stream Dac (on the top inside of the lid) One above the bridge card / power supply, the other over top of the digital board. The other iQSE was installed into the BHK Pre - center of the lid, right in front of the opening for the tubes.
After installing, I set the components back on the same rack, plugged them in, powered them on and let them sit powered on for 5-6 hours.
I started my listening around 8:30 pm last night, and I stopped shortly after 1:00 am.
I also have a science background (computer science), and the left brain, logical part of me doesn’t understand why or how these things should work. I wasn’t expecting any improvement, (perhaps some pseudo effect - like “maybe this is doing something”).
I did not compare back and forth, nor with just a single component at a time. I took a shotgun approach, DAC and PRE with iQSEs added.
So to me these small devices of who knows what, do make a difference, it is actually profound what they do in my system. The best word I can use that describes these is musical flow. There was no noticeable change in timbre or texture, but the music flowed very organically. I also could swear that the background is much quieter, well even at low levels, I heard subtle things in recordings that I didn’t realize were there before.
These things are not cheap - considering how small they are, but they do pay dividends - I think on the order of a $2K - $3K cable investment. Again, I didn’t feel as if they changed the tone, timbre or overall sound of my system, but it did allow the music to flow. Almost like PACE, articulation, and the naturalness or ease of music increased.
I purposely listened to some of my favorite artists that I have in heavy rotation now, and I feel as if my entire system has been raised a notch or two up. The music drew me in better than it did prior. My system always sounds musical, but with these devices in, you are more compelled to listen longer. Its like the system sounded more pure, closer to live. Not sure how else to describe. Again very profound, makes absolutely no sense, but they do work (at least in my system). YMMV.
I think for those with a DS DAC / BHK pre - these are a worthwhile investment - if your other components, and cables are well matched to your system. My personal believe is get the shelving, cabling and components right first, then tweak. I am keeping these in my system, and am begging to wonder if I will get additional improvements by adding a couple to my PPP and power amps.
I will keep listening for a few months before adding more (sometimes more is not better).
