I wonder if anyone else has had these observations.
I use my P20 to power my big monoblocks and a large home theater amplifier.
I only noticed today that when each amplifier is switched on the incoming distortion the P20 measures jumps 0.2%. Is this because pulling more current increases incoming line distortion to the P20. Or perhaps their big transformers echo noise straight through the P20.
Being more curious I moved The amps to dedicated 20 amp circuits with separate breakers and line connections. The incoming distortion then still increased the same amounts.
I see why know why Shunyata and AQ pitch using high current cords to conditioners from incoming power. The Noise Reduction cords conditioner to the power amps.
I thought dedicated lines would address distortions. Apparently not.
Anyone else have theories why P20 feeds distortion back to supply. Or have similar observations.
