Moving Coil DENON 103 is ok at 100 Ohms, but better at 300 Ohms
not to forget, my best cartridge tuning
So each mark, it is a step of 50 Ohms, for perfect adjustement
Good evening,
I have learn that rule of thumb is x 10, so it is 40 Ohm x 10 so 400 Ohms will be ok.
I also find the in the manual, it is written, 100 or more:
So for better tonal balance and better base, 400 seems what everyone recommended! In my old ear, it is better than 100. the truth is between 300 to 400, your call!
And gain, you choose between low and mid, your call
Before my PS phono stage, I had a Vista phono, that was working fine, but something was missing for me. The good thing, user have build a chart recommandation to start with, that I still use:
Cartridge load recommandation from user of Vista phono stage
