Qobuz HiRes on DSJ
Ok - so im a bit confused here.
Im playing a HighRes track from Qobuz - infact have played several (streaming) and Directstream displays this at PCM 48khz 24 bits.
Why am i not getting 192khz ?
The DS will display what it is receiving. Thus, it is not being provided with a 192kHz datastream.
got it :slight_smile:
tried Dexter Calling - 192khz it is.
This forum ROCKS - Thank You Elk!
Excellent!
These little mystery issues can be frustrating.
I use BubbleUPnP as the UI for Qobuz. It is set to display the technical information. I can see the bit depth and rate for any album or track. Some HiRes is genuinely at 24/48.
Its nuts…but Qobuz Hi Res beats the pants off Tidal MQA for my ears.
Its nuts cuz I would never have believed that there could be such difference in resolution/ clarity.
I agree. maybe not as big difference as you mention. it’s more subtle for me.
I use Roon and do notice I prefer the Qobuz high rez over Tidal MQA. I usually find thinking something sounds a bit off, I click the signal path and see it’s Tidal then click on the Qobuz version and change my library to the Qobuz version.
