Quick repair question
Hey, all. I replaced a faulty surface mount capacitor in a Bose Wave radio with a bent-over thru-hole. Unfortunately based on where it was I was afraid of shorting other items on the board if it contacted them once reassembled. So I put shrink wrap tubing around the barrel of the new capacitor. Is that likely to be a problem?
Replaced the one at the arrow:
So. Bad idea?
EDIT: this capacitor seems to only serve the CD player and not the amplifier circuitry. Just to be clear. It’s pretty low voltage.
New cap is a Nichicon CAP ALUM 22UF 20% 16V RADIAL
https://www.digikey.com/en/products/detail/UPW1C220MDD6TP/493-11376-1-ND/4319922
Thanks for your thoughts.
Mike
I had a first gen Bose Wave Radio (no CD, just basic radio) I got from my mother after she passed in 2004. After a few years, the screen started flickering to the point the screen was unuseable. I took it to the Bose outlet store and they gave me fifty percent credit toward a new one in exchange for the old unit. It was about 17 years old when it failed. Bose makes good products. The older stuff is probably even beter from a QC standpoint.
