Will my system benefit from a REGEN or is it too small?
I have a 2013 MacBook Pro with a DAC ifi nano, I have a 4TB WD external HD, I have a B & K Reference 5 S2 Pre Amp and a B & K Reference 200.2 S5 Power amp 225w rms, Also Paradigm system 100 speakers.
Over on the CA forum people are seeing great results on every type of system. At $175 it’s a no brainer, and if you don’t like what you hear I bet you can sell it for exactly what you paid for it. They are going like hotcakes.
Ifi nano is nice dac I have the micro it’s ok . I use it with one if my servers and without one t the sound change is easy to hear . Money well spent . Tonight I just tried the ifi micro DSd witha speaker setup I am using temporary and it’s nice. Not as good as DS but still,nice .
I recently got a Regen and connected it to my DS DAC USB port being feed from my Mac Mini. I wanted this as I’m running Roon on the mini and wanted to see if It would help the SQ. I have to say I’m am very surprised and happy with the results. It’s a great upgrade and the SQ it brings to the table is well worth the $175. If your planning to stream via USB I highly recommend picking one up.
froma good server. I have some say it still helps and maybe it does but this means there server is below par for the task.
I think this is a good product for all who do not have a good server. The masses use a laptop a big no no period but they prevail. I go to shows to listen to hi end stuff mega bucks and see laptops. It’s a shame. Even Paul our leader and knows far more does not own one
this does not make him wrong or me right
and it shows this dac has great quality from most any source. But servers or Usb converters are a must for the best projection
I recently got a Regen. I haven’t tried it yet with my PSDS but I have tried it in two other systems. One using a Mac Mini headless server running Roon via Wireworld Platinum USB to a dCS Upsampler/DAC. The other used an Aurender server into a Berkley Reference DAC, I’m not sure which USB cable was involved because it was at a dealer. In the case of the dCS system the Regen made no noticeable difference. With the Berkley it actually degraded the sound. I’m not sure what, if any, conclusions to draw but will see if I can hear a difference with my PS Audio DAC which is normally fed via AES from an Aries.
Try an let us know . I have tried a few USB converters always with positive improvment until the Hugo and DS dac both were hurt by them.
But the REGEN I thought is not a true converter. But who knows. I do not expect it to help beyond a server but we will see. . There are some who post positive with a DS dac. As you are using a laptop I expect improvment . Please post for us .
I want to clarify a statement I have made a few times.
When I say laptops are not good I mean for dsd
pcm weather it’s clean or not works fine and only on loud hinted complex music does this become obvious unless you knew what to Karen for or know the magic very well.
During these passages the staging can move or become blurry. The over stsging may move around.
Now on dsd it’s different or sound ok but it’s not how good dsd sounds it does not blur it’s just not clean and shiny without being Fatiging.
I think now that the ds does good dsd with the past couple of firmwares a regen and an I7 cpu can give a good showing of this fine dac
an I5 is just not good enough for me and I have heard many and have pointed this out in person to them. Even a laptop with a an I7 beats up a desktop with an I5 on dsd.
but laptops in general for me loose the hi end details this dac Can give us.
There is a thread on the device and it may contain settings and there meanings.
Glad it’s making an improvement.
Mans there is no system too small for a cheap device like this. I can hear improvements with CIEMS and they do not have the resolution of good speakers or headphones
