Good day, audio folks.
I have a Bryston SP-3 that’s getting long in the tooth and I am considering replacing it. I use it for both music from a DSD Mk1 DAC and video sound from Xfinity. The SP-3 is perfect for me, though it doesn’t have 4K HDMI. (Later SP-3s did, but not mine and the module is no longer available.)
My number one priority is music, but I’m finding that most (all?) contemporary AV pre/pros digitize even analog inputs.
Q#1: Are you aware of a current AV pre/pro that has pure analog passthrough? (like the SP-3)
Q#2: Is the extra A-to-D/D-to-A conversion really a problem with modern pre/pros?
If the answer to Q#1 is “no, the SP-3 and others of its time are extinct”, and the answer to Q#2 is “no, that really isn’t a problem”, what brands would you consider? I’m looking at Anthem (new) or McIntosh (used or new).
Q#3: Any thoughts on abandoning the whole multi-channel/surround thing and go back to exclusively two channel?
Thanks and happy listening!
Chris V
