Running a new dedicated 20 amp line materials
Electrical supply houses will have 10/2 available, solid core. No need to order on-line. Call them to see if they sell retail or not first.
Sounds like the flunky at Home Depot didn’t know what they were looking up.
https://www.homedepot.com/p/Southwire-250-ft-10-2-Solid-Romex-SIMpull-CU-NM-B-W-G-Wire-28829055/202316274
He needs THHN wires, not Romex. It has to be pull into the wiremold. Romex is not permitted in his building. But solid #10 THHN is readily available where I live in Home Depot or Lowes or any other electrical supply house. I don’t know what the problem in his area. Like I said, stranded wire is fine also, just terminating it is tricky.
My bad, haven’t followed the whole thread. Agreed, THHN should also be available at any HD or Lowe’s nationwide. I vote solid vs. stranded.
https://www.homedepot.com/p/Southwire-500-ft-10-Green-Solid-CU-THHN-Wire-11599801/202316546
There might be a supply problem for solid 10 gauge thhn wire at the moment. I know Lowe’s looked on the computer, and it wasn’t even available for order. I went ahead and ordered some on Amazon; it should arrive in the next few days. Sadly, lots of extra left over; I needed 32 feet for each wire, and it was only available in 50 feet rolls.
I found 75 feet pieces on Amazon just now. If you cut each piece in half, you will have less leftover.
I don’t know if it’s too late but I found the wires cheaper on Ebay. 75 feet each color and 40 feet #12 green. You can use #12 green since it is 20 amps circuit and you only need i piece.
![thumbnail-6|666x500]
there is (are) sonic reasons to stay with 10 gauge…
All the current conductors are #10 solid THHN. The ground safety wire can be #12. The ground wire size has no bearing on sound. The reason for #12 ground is to save space as it may be too crowded in the wiremold.
Actually, all that is needed is 75 feet of one color, red or black #10 THHN and cut in half to get two pieces of one color. It doesn’t matter if it’s the same color for the two circuits.
Thanks for looking. I had already ordered the wire on Amazon, though I ordered #10 for the ground wire as well.
