Aloha,
Has anyone tried the SGCD I2S connection using the Singxer SU-1 (or similar gadget) to convert USB to I2S?
Results? How does it compare to USB?
Thanks.
Aloha,
Thanks.
There have been a number of references, see click
Thanks. I read through them. I didn’t see anything referencing the SGCD with the Singxer SU-1.
I’m not entirely clear if the converter works with PS Audio I2S. The feedback wasn’t conclusive.
Thanks.
I believe it does. You might give EJ a call to confirm.
The Singxer works perfectly with the Directstream. I use the Kitsune modified version SU1 with Wireworld HDMI.
+1 same here
My experience confirm what’s above.
